Hot Topics in TidBITS Talk for 15-Dec-08
Grey Lines Mar MacBook Air Displays — Is the problem with the new MacBook Air displays widespread enough to consider holding off on buying one? (2 messages)
Font used by Dictionary.app in OS X? — When the phonetic spellings in Mac OS X’s Dictionary application go screwy, a reader suspects a problem font, leading to a discussion of which fonts in the system are safe to deactivate. (8 messages)
Keyboard backlight — How do you set the keyboard backlight on some Mac laptops to adjust itself automatically according to a room’s light level? (3 messages)
Low ranking for the new MacBook — Readers discuss the limitation in MacBooks where video content can’t be played on non-HDCP compliant displays. (4 messages)
Apple Confirms Antivirus Software Is (Usually) Unnecessary — Readers discuss the current state of virus vulnerability on the Mac. (11 messages)
