12 comments
iPhone 12 and iPhone 12 Pro: A Roundup of Reviews
The reviews are in! Well, some of them. Pundits favored by Apple with early review access have started to publish their initial impressions of the iPhone 12 and iPhone 12 Pro. It will be a few more weeks before we see reviews of the iPhone 12 mini and iPhone 12 Pro Max—we suspect those will appear on 13 November 2020.
Here are some highlights from the reviews, which had a surprising amount of consensus. We’ll focus on the key aspects of the new iPhones and share reviewer opinions about each.
Overall Design
Of course, no single feature defines the iPhone experience. The combination of materials, shape, and other factors make up the gestalt of each iPhone.
Dieter Bohn, who reviewed the base iPhone 12 for The Verge, said,
Overall, though, this design just feels more elegant and confident than the past few years of iPhones, including even the big iPhone X redesign. … The iPhone 12 is the first iPhone in several years that really does feel like something new. But I can’t point to any specific single feature that makes it feel that way. The 5G is fine. MagSafe is convenient, but we’ll have to see if there’s a real ecosystem there. The OLED screen is lovely but also kind of table stakes for smartphones these days. The new design is elegant and modern, but it’s hard to tell you to buy a phone because it’s pretty.
In TechCrunch, Matthew Panzarino wrote,
Where the iPhone 12 Pro is jewel like, the iPhone 12 is fun, bright and utilitarian. … The blasted aluminum sides of the iPhone 12 welcome you to grab and go … The 12 Pro is likely the most premium feeling piece of consumer electronics I’ve ever touched.
The main criticism of the industrial design of these new models was that they show fingerprints. Talk about a first-world problem.
Panzarino called out the stainless steel coating in particular.
The PVD coatings of the stainless steel are deep and rich on the Pro—but they gather fingerprints like they were in the business of collecting evidence.
John Gruber of Daring Fireball concurred.
The shiny steel band of the 12 Pro is a fingerprint magnet — they wipe away easily, but the aluminum band of the 12 never shows any signs of having been touched,” Gruber said.
Bohn also agreed.
Unfortunately, the rear glass is super glossy, super prone to picking up fingerprints, and as susceptible to picking up tiny little micro-abrasions as ever. Most people will put a case on their phone anyway.
5G and Battery Life
Much has been said about the new 5G capabilities of the new iPhones. The general consensus is that the fastest 5G speeds are amazing… if you can find one of the few exact spots where they’re available.
Bohn said:
The networks simply aren’t built-out yet, and despite lofty promises from carriers, I don’t know how long it will be until they are. … Getting 2,400Mbps and using it to download an entire Netflix season really is awe-inspiring. Walking half a block and seeing speeds drop down to plain old LTE speeds is not.
Matthew Panzarino summarized the situation well.
The fastest flavors of 5G are available only on a few blocks of a handful of major cities at the moment and though the speeds are absolutely incredible there, that will have very little to do with the wider experience of buyers over the next 6 months. And, of course, millimeter-wave 5G is not live for customers outside of the U.S. currently.
John Gruber had trouble finding 5G service, but once he did he was amazed by its speed.
 Basically, Verizon claims to offer ‘5G Nationwide’ — a.k.a. Sub-6GHz 5G — across the whole metro region except for the most densely populated area right in the heart of Philly. Which is where I live. I walked into areas that are red on Verizon’s map, but I never saw any regular 5G service. Only LTE. I pretty much live my life in Verizon’s pink zone.
And — I’ll repeat — holy s–t is Verizon’s 5G Ultra Wideband fast. Using Ookla’s Speedtest app for testing, my LTE service here in Philly is generally in the range of 50-120 Mbps down, 10-20 Mbps up. Not bad. With 5G Ultra Wideband, I typically saw 1,200-1,800 Mbps down, 25-70 Mbps up. At a few spots I consistently saw 2,300-2,700 Mbps down. Wowza.
On the downside, using 5G appears to have a significant impact on battery life. Tom’s Guide ran tests that produced alarming results.
The regular iPhone 12 lasted just 8 hours and 25 minutes over AT&T’s 5G network. Last year’s iPhone 11 lasted a whopping 11 hours and 16 minutes over 4G. To compare, we switched the iPhone 12 to 4G-only, and it endured for 10 hours and 23 minutes.
It’s also worth noting in those results that, even with 5G turned off, the iPhone 12’s battery drained almost an hour faster than the iPhone 11’s. That may be due to having smaller batteries.
Dieter Bohn saw a less dramatic decrease in battery life from last year’s iPhone 11.
Battery life is good but does seem to be a small regression from the iPhone 11 (an absolute battery champion). The fact that Apple felt the need to create a special mode for silently turning off 5G is a little worrying in terms of battery life. Luckily, I don’t think the battery life on the iPhone 12 is bad at all. I can get through a full day without much issue. On the other hand, I have to admit that it’s easier to kill this thing with a full day of heavy use than the iPhone 11.
Nilay Patel, who reviewed the iPhone 12 Pro for The Verge, believes the battery life reduction will largely depend on how much you use 5G.
In the end, I think iPhone 12 Pro battery life is going to vary widely for people depending on how much they use 5G—especially mmWave 5G—so this is something we’ll have to track over time. But I would definitely not expect the “try and stop me” battery life we saw on the regular iPhone 11.
The battery life reduction wasn’t universal, however. Panzarino saw similar performance to the iPhone 11 Pro.
Battery usage seemed to be much in line with the iPhone 11 Pro. I typically clone all of my test devices off of my current devices and then do testing on performance once indexing has settled down. I got around 15 hours of heavy usage on the iPhone 12 Pro every day. The iPhone 12 seemed similar but it’s hard to say because I had to focus on one main device.
Finally, Gruber has concerns over what 5G will do to data caps.
Data caps are another practical concern. Anything you do that can make use of these insane speeds can chew through 15-30 GB of data pretty quickly. Download Xcode once and boom, there goes 11 GB. But 5G will help you blow through your data cap really fast.
However, Bohn said iOS tries to regulate usage based on your data plan, which could prevent some problems.
The iPhone will also try to be aware of your data plan, and if it knows you have unlimited, it will use 5G more freely for certain things. Apple will even allow it to download full iOS updates over 5G if you’re on unlimited. If you change your plan or don’t want it to do that, you might need to go diving through various settings.
Bohn also mentioned some interesting technical aspects of 5G on the iPhone 12:
  • What’s weird is that when the iPhone is limiting you to LTE speeds, it will still display the 5G icon in the status bar. It’s now an indicator of the best speed available to you, not the actual type of connection that’s actively in use. You can turn Smart Data off if you like, but I left it on and honestly never really felt like I was being throttled.
  • Some networks—including Verizon—require you to get a new 5G-compatible SIM card. So if you’re not getting 5G and you think you should be, that may be the issue. You may also need to adjust your plan.
  • Apple also says that you might get faster tethering speeds over Wi-Fi than tethering over a wired Lightning cable, thanks to optimizations it has made. Wi-Fi tethering could be as much as four times faster than before in optimal conditions (including, perhaps Wi-Fi 6 on the tethered device). Since it’s a hassle for me to even find a mmWave signal, I haven’t had a chance to fully test this.
  • …5G won’t work on your iPhone if your carrier doesn’t directly work with Apple to light it up. Unlike previous networks, you can’t go in and just manually set an APN and MMS settings and be good to go on 5G. That shouldn’t be a problem for the vast majority of people, though. Apple has worked with over 100 carriers in 30 markets to enable 5G on the iPhone, including all three major carriers in the US—but if you use an MVNO, you should double-check that 5G will work before you buy.
Cameras
As always, Apple put a huge amount of effort and emphasis on the camera improvements in the new iPhones, but the actual differences may not be worth an upgrade. Dieter Bohn saw an improvement over the iPhone 11, but not enough to justify an upgrade.
For me, the bottom line on the cameras is I definitely see a marked improvement over the iPhone 11, but they’re not enough to compel an upgrade. That doesn’t mean the iPhone 12 isn’t a massively good camera. It is, and the combination of performance, simplicity, and just plain good quality continues to impress.
Similarly, Nilay Patel found the improvements in the iPhone 12 Pro to be minor compared to the iPhone 11 Pro.
Last year I said the iPhone 11 Pro had the best camera on a smartphone, and it’s not like the iPhone 12 Pro went backward. But it’s only a small step forward—enough to stay just ahead of the competition. Most of the improvements are fairly minor.
Unless you are extremely committed to either AR gimmicks or night mode portrait photos, I don’t think you’ll get much value out of the iPhone 12 LIDAR sensor. When you take photos in regular light, the camera focuses just like always; the LIDAR sensor isn’t active. In many ways, it feels like LIDAR is mostly on the phone so that Apple and other people can figure out what to do with it in the future.
However, Matthew Panzarino was impressed by the improved Portrait Mode.
The portrait mode on iPhone 12 and iPhone 12 Pro are greatly improved in one major respect: they do a much better job of segmenting images along the border of things like leaves, hair, fur and other areas of fine detail.
But what about the new HDR video capture capabilities of the iPhone 12 Pro? Panzarino doesn’t think most users will take advantage of it.
I’m going to be flat out honest with you: the vast majority of iPhone users will never even be able to access HDR footage or workflows, and will never ever need this. If you do most of your video shooting on an iPhone and then share directly to social networks or in Messages, HDR will likely bring you no major benefit. The iPhone 12 shoots pretty amazing right out of the camera 4k footage in 30 and 60 fps.
Patel agrees, but he thinks it will become more useful over time.
Dolby Vision video on the iPhone is a little complicated, and there will be some compatibility goofiness at the start. But over time, I’d expect it to fade away. TV manufacturers and social platforms have a lot of incentives to figure out how to play back people’s iPhone videos well, after all.
If you want to learn more about the iPhone 12 Pro’s support for HDR video capture, I highly recommend reading Patel’s full review, which goes into great detail about its technical details.
MagSafe
MagSafe is the iPhone 12’s new magnetic charging and accessory attachment system. For Dieter Bohn, MagSafe was the most interesting of all the new features of the iPhone 12.
But how does MagSafe compare against charging with a Lightning cable? Qi wireless charging is notoriously slow and inefficient, but Bohn noted a marked improvement over Qi.
It’s the difference between wireless charging being annoyingly slow and being acceptable. In my testing, I would get around 40 percent charge in an hour. That’s slower than the fastest wireless charging systems out there and much slower than a cable, but it’s also easy and convenient.
Bohn noted other advantages MagSafe has over Qi.
NFC also lets Apple do cute little things like light up a ring on the screen when it detects that an accessory has been attached. There’s a blue ring for a blue case, for example.
If you’ve been frustrated by trying to line up your iPhone correctly on a Qi charger, Matthew Panzarino said MagSafe is a lot easier.
This process is way faster than fiddling with a Qi charger, and way less frustrating. Though I have had some luck with upright Anker chargers, the pad style chargers have always been crap at this. You have to fiddle to get them on right and often wake up realizing that you didn’t get it quite centered and your phone hasn’t charged at all.
John Gruber pointed out that MagSafe is more akin to Lightning than Qi.
I dig MagSafe charging. But it definitely is not a dock or a charging mat, like tabletop Qi chargers are. It sticks to the iPhone, so if you just pick up the iPhone while it’s charging, the MagSafe puck stays attached. It’s best thought of as a magnetic replacement for a Lightning cable, not a magnet charging pad.
The signs seem to point to Apple eventually dumping Lightning in favor of MagSafe. Panzarino even said so point blank.
And yes, it’s quite obvious that the MagSafe charger is paving the way to a portless iPhone altogether. Apple will be contributing many of the “enhancements” it is making to the Qi standard back to the consortium so you may see more aligned magnetized stands in the future. This is not a “pay us dearly to license this tech” situation, Apple wants this standard to proliferate.
Bohn suspects the new focus on MagSafe is why Apple hasn’t switched from Lightning to USB-C.
I’m less in favor of the decision to stick to the Lightning port for charging. A major redesign is an opportunity to switch over to the more common USB-C port, the same port that Apple’s own computers and tablets use along with every other Android phone and many, many other gadgets. The fact that Apple didn’t have the courage to do so tells me that its long-term plans may have more to do with MagSafe than anything else. I don’t love Lightning, but I have to admit it’s better than literally nothing when it comes to wired charging.
Display and Ceramic Shield
Finally, the reviewers raved about the iPhone 12’s OLED screen, except for its 60Hz refresh rate, which lags behind Android competitors.
Dieter Bohn harped on the relatively slow refresh, but excused it for the base iPhone 12 due to the smoothness of iOS.
One of the reasons Apple was able to reduce the size of the iPhone 12 is that it has switched over to an OLED screen. That helps reduce the bezels and also keeps them perfect even all the way around the phone, while at the same time keeping the actual viewable screen the same 6.1 inches as the iPhone 11.
Many Android phones at this price point (and nearly all of them that cost more) have a 90 or 120Hz refresh rate, which makes scrolling and animations smoother. The iPhone is locked to the same 60Hz it’s always been.
This is a tech spec argument, but it is something that you can feel when you scroll or navigate around a phone. Apple ships such a screen on the iPad Pro. I think the iPhone 12 gets away with leaving it out for two reasons: one, iOS already feels smooth and fast natively, and two, this is the lower-cost iPhone, so it isn’t a surprise to see a standard refresh rate. The iPhone 12 Pro models lacking 120Hz is a little more jarring.
Nilay Patel was much more critical of the lack of 120Hz on the iPhone 12 Pro.
There are excuses to be made about Apple’s sales volumes and available display panel supply, but in the end, a 60Hz display is simply not very… pro. Indeed, Apple’s own iPad Pro has a ProMotion high refresh rate display. If you’ve only ever had iPhones, you will not really notice this because it is the same as ever. But if you have used a 120Hz display, the difference in smoothness when scrolling is certainly noticeable.
As for the new Ceramic Shield screen, it seems to work! Bohn accidentally put it to the test.
It uses ceramic crystals within the glass itself to improve drop resistance over the iPhone 11. Apple says it’s four times better, which is a good thing because screen repair costs have gone up this year. I can’t test that with our review unit (at least, not intentionally), but I did have a totally accidental drop to concrete from three feet that stopped my heart but only put a barely perceptible ding in the aluminum. Scratch resistance should be about the same as last year.
iPhone 12 Versus iPhone 12 Pro
The iPhone 12 and iPhone 12 Pro are the same size and, apart from the camera, aren’t that different. There seems to be some consensus that the iPhone 12 is more fun than the iPhone 12 Pro.
John Gruber preferred the blue of the iPhone 12 to the blue of the iPhone 12 Pro.
Subjectively I think the glossy glass iPhone backs look better too. Both of these blue iPhones look great, and I think both colors will prove very popular, but there’s no question to my eyes that the blue iPhone 12 pops in a way the staid pacific blue iPhone 12 Pro does not.
Matthew Panzarino made a comparison to watches.
Overall, the iPhone 12 feels like the Timex to the iPhone 12 Pro’s Rolex. It’s a great daily driver that feels light and fun. The iPhone 12 Pro leverages refinement as a category differentiator projecting a solidity that plays into the “Pro” posturing.
Nilay Patel addressed the question of whether the iPhone 12 Pro was worth the extra money directly, and came down on the side of the iPhone 12.
So the real question for the iPhone 12 Pro is whether the small list of extra features justifies a roughly $200 price bump from the standard iPhone 12. And if you’re spending that much more, it might be worth it to wait a little while longer and spend another $100 on the iPhone 12 Pro Max, which will add a bigger display and a larger main camera sensor with a very intriguing new sensor-shift stabilization system that could offer a huge jump in picture quality.
That leaves the 12 Pro in a weird spot, and really, I think it comes down to how much you might use the telephoto lens or shoot portrait photos at night.
Video Reviews
This year, quite a few of the early reviews are on video, so if you’re doing your due diligence on the new iPhone 12 models, these three are worth watching.
The ever-amusing Joanna Stern of the Wall Street Journal filmed her review at MetLife Stadium to comment on the supposed utility of 5G in large public venues. Her video is just under 7 minutes long and has been seen more than 120,000 times already.
Rene Ritchie, formerly of iMore and now an independent YouTuber, posted a mega 45-minute review of both the iPhone 12 and 12 Pro that has racked up over 377,000 views so far. Make popcorn first.
After Marques Brownlee did an unboxing of the iPhone 12 and offered a demo of MagSafe, he published a full review of the iPhone 12. His video clocks in at 18:17, and, to give you a sense of the power of a YouTube star, it already has over 4 million views.
Comments About iPhone 12 and iPhone 12 Pro: A Roundup of Reviews
  1. Great roundup! I’m waiting on the 12 Pro Max - only because of the upgraded camera features. I hope to see a similar article then, but may be tempted to pre-order as soon as it’s possible to do so…
  2. Pet peeve coming. Whinging by a reviewer about 1st world problems doesn’t enhance the reviewer’s credibility to regular readers like members of HMUG. Like Josh said on fingerprints: talk about first world problems?
    In a sense, the whinging about 64 GB not being enough storage for an iPhone or iPad in a given reviewer’s eyes was and is ridiculous. At HMUG we are mostly mere mortals. We don’t take 4K videos intentionally. We’re normal people. Most of us still don’t use up all 64 GB storage if that’s what we have. I respond to reviewers saying that 64 GB is a “joke” that they’re presumptuous in speaking for the rest of us by using themselves as an example of what’s needed by the average person. They’re wrong, and they’re in denial.
    Just a longtime pet peeve: reviewers are prosumers or professionals or both. Their needs are above those of normal users, and yet their reviews don’t acknowledge this with the whinging as I’ve said before. It’s not helpful.
    FWIW, John Gruber doesn’t fall into the trap as much, but even he does, sometimes. His review of the iPad Air 4 has the same sense of entitlement in his concluding paragraph. John is one of the very best writers out there, and he’s as technically sound as it gets. I greatly respect him. This last paragraph on iPad Air 4 is a bit dismissive of “normals”. See for yourself.
    Each of the other reviewers linked by Josh in the TidBITS post has a little pro level whinging in their reviews that are not helpful to average people. It’s not because they’re bad people or writers. It’s because they’re exceptional. But exceptional literally means they’re exceptions to the rule or the average. Their writing and thoroughness are exceptional: they’re really good at what they do. They don’t mean to, but they end up insensitive to the rest of us normal folks.
    This turned into a long rant, but I’m tired of getting questions from HMUG members who read something and say in essence: “why is this described to be so inadequate or bad? Does that mean it’s a problem or flaw and I shouldn’t buy it?”
    I have to explain the above, and help them come to an understanding that works for them.
  3. Thank you for these reviews and info on the 12 models! While some might disagree that 64GB is a joke, in real life use and lifespan of the phone, the iOS and apps generally take up 20% of that 64GB (have we forgotten the iOS updates to the 8/16GB IPhones that could not because it needed an additional 4-6GB for the update file alone?). And that the 64GB is really not that but more like 56GB free with the iOS taking up 6-8GB alone. And having 12MB pixel camera, means 36MB per image file. Having 64MB*(lets just say 56GB free) means about 1500 images. I just dealt with someone’s iphone migration that had 9400 images on it (it was an SE model, with 64GB storage–that was almost full). So you can see that many users do not manage their storage or drink the Apple iCloud elixir and subscribe to store there. I wouldn’t replace my current iPhone with anything less than 128GB (and Apple knows this…oh yes they do).
    I saw a review (iPad Air Youtube review - The Verge) by Dieter Bohn that seemed rather unbias. I might replace mine with this when it dies (again). I have an iPad air that failed from a dead chipset ($250 to repair) and was $50 more to just replace. I keep it around to remind me of Apple’s failure at quality…and if someone were to file a Class Action on this model of Air failing for others. But that is another rant.
  4. I think Josh did an excellent job of rounding up the reviews, and reading the different takes they all had will help all levels and interest groups of mobile phone buyers make very informed decisions. And they did reinforce my decision not to upgrade my 8+ until 5G is more widely available.
    Very many relatives, friends and acquaintances I know are constantly snapping photos on either iPhones or or Androids. A few are prosumers, but most are not. Though it’s been many months before social distancing became a thing, I’ve always seen people snapping away on mobile devices, phones just about always and just about almost everywhere. For whatever reason, I know quite a few people who prefer to keep photos on their phones because they don’t trust cloud services. And road warriors that I know that travel a lot for work with do also like to have more storage space on their phones, especially if they do a lot of airline travel. When it comes to Apple devices, I’m just a 'sumer across the board, nothing resembling a pro or a prosumer.
    About Gruber being “dismissive,” you should hear me and my other family members who live in NY metro and the relatives from Chicago arguing about which regional pizza style is superior. Many restaurant and food reviewers have attitude about choices and pricing as well. Film, music, art and book critics likewise. I’m personally glad that Josh provided a spectrum of opinions, as TidBITS readers are a very varied group encompassing a wide variety of skill levels and interests. Every reader can focus in on their particular needs.
  5. It can be tough for tech journalists to internalize the perspective of “normal” users. As you say, we tend to be power users in the first place, so we have a different view. I think a lot of reviewers focus on nitpicky little things because they want to appear as critical and unbiased instead of giving in to their love of new toys.
    I always learn a lot by helping friends and family with technical issues, because their view of things is so different.
    I disagree on the storage sizes, though. One of the issues I struggle with the most often is family members not having enough free space on devices. I’ve been working on an article for TidBITS where I document a scenario where that was a real hurdle. There’s a bit of a myth that less-technical users need fewer computer resources, but in my experience they need more. A power user can work around slow processor speeds and limited storage, but these things frustrate regular people.
    But I think pretty much anyone who buys an iPhone 12 or 12 Pro is going to be happy with it. For that matter, the iPhone I’ve been recommending for a lot of people is the new SE. I realize that somewhat contradicts what I said above, but the SE really is plenty of phone for most people, and is a real bargain. That said, I try to push them toward the 128 GB model, since it’s only $50 more and will give them so much more breathing room.
  6. This is very true. It’s hard for power or experienced user to put ourselves in the mindset of a newbie or non-techie. So many times I’ve shown a fabulous feature to a “regular” person and they’ve totally popped my balloon by pointing out some silly average person usage that seems irrelevant to me (like a phone’s color or a “puzzling” user interface that seems obvious).
    I just got my 79-year-old mom a new iPhone 12 and her main complaint is Apple’s clear case is too slippery and she keeps dropping the phone. :roll_eyes:
    (BTW, you mentioned storage, which definitely depends on the person. Her old phone was 64GB with 33GB free, so I got her the 64GB and it’s fine for her as it’s more than half empty. I got the 256GB for me.)
  7. Jason Snell’s review is now up at Six Colors:
    And for photographers, Austin Mann’s review is also great (though I’m still waiting to see comparisons with the iPhone 11 and iPhone 11 Pro).
  8. Please spread this concept far and wide. Over and over I see ordinary users struggling with under-resourced systems, reinforcing their beliefs that “computers are difficult” or, worse, “I just don’t get along with computers.”
    I can get by just fine with a 64GB phone (my antepenultimate iPhone was a 64GB 6s+) but only by doing the kind of juggling I would never expect a non-techie user to be able to pull off without a struggle. Heck, I could run my life on a Raspberry Pi if I had to (fortunately, I don’t) but most ordinary users need far more power, memory, and storage to be comfortable and efficient.
    Give the developers the low-end machines! :wink:
  9. This reminds me of the first company I worked for after graduating college. It was their policy to give the developers (especially the newest ones) underpowered machines in order to force them to write efficient code. If they were able to get good performance out of their developer machines, it would work great on customer machines. And if they couldn’t get good performance, we would re-think a feature’s design to come up with one that could perform well on that hardware.
    Overall, this worked up to a point. The biggest problem was that these underpowered machines took a while to compile the software so a lot of time was wasted there. On the other hand, our customers loved the results.
  10. The Raspberry Pi is an excellent example. I recently purchased a Raspberry Pi 4 for ham radio purposes, and I was aghast at how slow it is. I’m patient enough to deal with it, but I absolutely wouldn’t want to hand one off to a less-experienced person.
  11. I got mine yesterday it’s a bit like a big 4 which was my favourite model I just loved the engineering and this one has the same feel. No e sim but the dual SIM card tray is cool. Still working my way through things but overall it’s a winner so glad I bought the stock.
Avatar for ace Avatar for jcenters Avatar for ron Avatar for DevKom Avatar for xdev Avatar for MMTalker Avatar for mikesan Avatar for scstr Avatar for Shamino Avatar for macanix
