How Apple Works Around Battery Chemistry Limits with Fast Charge and Optimized Battery Charging
The most significant limitation for mobile devices is power. Engineers keep finding ways to cram more transistors into chips, but batteries have hit a brick wall of physics, forcing hardware makers like Apple to invent creative workarounds for those limitations.
The inherent problem is that lithium-ion—the current battery chemistry of choice—isn’t particularly stable. It’s more forgiving than older technologies like nickel-cadmium, but it’s all too easy to shorten a lithium-ion battery’s lifespan by:
- Draining the battery completely
- Holding the battery at a 100% charge level
- Letting the battery get hot
Users have two conflicting desires with regard to batteries, whether or not they realize it. In the short term, they want the device always charged and ready to use—little is more frustrating than running out of power earlier than you’d expect in a day. Long-term, they want the battery to maintain its capacity for as long as possible—replacing a battery to bring a device back to decent daily battery life is expensive and annoying.
In an effort to meet both of these conflicting desires, Apple has developed two seemingly contradictory technologies: fast charge, which does what it says, and Optimized Battery Charging, which actually makes the battery charge more slowly.
Fast Charge
Certain Apple devices—most notably the iPhone 8 and later, USB-C iPad models, and 14-inch and 16-inch MacBook Pro models—support fast charge, which can boost the battery up to 50% in 30 minutes.
Fast charge requires a sufficiently powerful charger and appropriate cable—it does not work with wireless MagSafe and Qi chargers. For each of the device families, you need:
- iPhones: At least an 18-watt (20-watt for the iPhone 12) USB-C power adapter that supports USB Power Delivery (USB-PD), plus a USB-C to Lightning cable
- iPads: At least a 30-watt USB-C charger with a USB-C cable
- 14-inch MacBook Pro: At least a 96-watt power adapter plus a Thunderbolt, USB-C, or MagSafe 3 cable, or an external display with 94-watt power delivery via Thunderbolt 3 or USB-C
- 16-inch MacBook Pro: A 140-watt power adapter plus a USB-C to MagSafe 3 cable
Fast charge works by delivering more power to the device from the adapter. But with great power comes great responsibilityheat, leading some to believe that fast charge shortens your battery life. However, Marques Brownlee explains that fast charge doesn’t typically reduce your battery life by much, if at all, due to various techniques that reduce the amount of heat generated.
But fast charge only takes a battery to 50%. To get the rest of the way in a manner that doesn’t result in the battery sitting at 100% for a long time, Apple developed Optimized Battery Charging.
Batteries don’t like being held at 100%, but users want their batteries to be at 100% when they start the day. How does Apple walk that line? Starting with iOS 13 and macOS 10.15.5 Catalina, Apple has provided features to reduce the maximum charge to extend the battery’s life. The first is Optimized Battery Charging.
Optimized Battery Charging uses machine learning to guess when and where you charge your devices the most and hold the battery’s charge at 80% until it thinks you need it to be at 100%.
On TidBITS Talk, David C. provided a great technical explanation of Optimized Battery Charging:
Apple’s optimized battery charging is a variation on this. It uses constant current charging until the battery’s charge reaches about 80%. Then instead of doing constant-voltage at a fixed voltage, it will dynamically select voltages so it will reach 100% shortly before it thinks you will remove the device from the charger. For example, if your usage history says you remove it from the charger at 8:00am every morning, it might try to reach 100% at 5:30am, even though a traditional constant-voltage charger might be able to bring it to 100% at 2:00am.
In theory, you should rarely notice this feature because it works while you’re asleep. In About Optimized Battery Charging on your iPhone, Apple says:
Your iPhone uses on-device machine learning to learn your daily charging routine so that Optimized Battery Charging activates only when your iPhone predicts it will be connected to a charger for an extended period of time. The algorithm aims to ensure that your iPhone is still fully charged when unplugged.
Optimized charging is designed to engage only in locations where you spend the most time, such as your home and place of work. The feature doesn’t engage when your usage habits are more variable, such as when you travel.
Optimized Battery Charging is location-specific, as you can tell by the fact that the following settings must be enabled for it to work on an iPhone:
- Settings > Privacy > Location Services > Location Services
- Settings > Privacy > Location Services > System Services > System Customization
- Settings > Privacy > Location Services > System Services > Significant Locations > Significant Locations
When Optimized Battery Charging is enabled on an iPhone, a notification appears on your screen. To bypass it and fully charge your battery, touch and hold the notification and tap Charge Now. You can also turn off Optimized Battery Charging in Settings > Battery > Battery Health, but that’s probably a bad idea unless you’re regularly starting the day with less than a full charge.
Optimized Battery Charging works slightly differently on Mac laptops, where it prevents a battery from being held at 100% for a long time if you regularly leave the laptop plugged in. When you click the battery icon in the menu bar, you may see Charging on Hold. You can then choose Charge to Full Now to override Optimized Battery Charging and charge the rest of the way.
To turn off the feature, go to System Preferences > Battery > Battery and uncheck Optimized Battery Charging. You can disable it permanently or just for a day. Again, don’t do this unless you’re regularly butting heads with the feature.
As far as we can tell, iPads don’t support Optimized Battery Charging.
Battery Health Management
Beyond Optimized Battery Charging, iPhones and iPads have a charge management feature that temporarily reduces the battery’s maximum charge capacity when devices are constantly plugged into power. Apple says:
iPad with iOS 11.3 or later and iPhone XS, iPhone XS Max, or iPhone XR with iOS 12 or later include a charge management feature to help maintain battery health, which monitors these devices for use in these charging situations and, as required, reduces the maximum capacity of the battery. The battery indicator will display the charge percentage based on this adjusted maximum capacity. The maximum capacity will revert back to the nonadjusted level when iPad or iPhone is no longer connected to power for prolonged periods and as conditions and battery health allow.
On iPhones and iPads, this charge management feature is automatic, and you can’t turn it off.
Apple calls a similar feature on Macs “battery health management.” It works slightly differently on M1-based Macs and Intel-based Macs. On M1-based Macs, macOS will temporarily reduce your battery’s maximum charge capacity to extend the battery’s lifespan:
Battery health management is designed to improve your battery’s lifespan by reducing the rate at which it chemically ages. The feature does this by monitoring your battery’s temperature history and its charging patterns.
Based on the measurements that it collects, battery health management may temporarily reduce your battery’s maximum charge. This happens as needed to ensure that your battery charges to a level that’s optimized for your usage—reducing wear on the battery, and slowing its chemical aging.
You cannot disable the feature on M1-based Macs, but you can on Intel-based Macs by going to System Preferences > Battery > Battery > Battery Health and unchecking Manage Battery Longevity. Again, we generally recommend against disabling it, but if it’s preventing you from charging to the level you need at a particular time, it might be worthwhile to turn it off.
In the end, as frustrating as it is that battery technology hasn’t evolved in step with the computational capabilities of our devices, it’s nice to see that Apple is using some of that processing power to make the most of what our batteries can do.
Sometimes I think my iPad or phone should be done charging but I’m stuck using with a pulling cord because charging slowed - now I know why.
I prefer to use the excellent utility FruitJuice in place of the regular battery menu. It tells me how long to use the Mac for each day unplugged, and having completed that, tells me to plug in.
Unfortunately, Fruit Juice is going into dormant state and will no longer be sold with support lasting only until year’s end:
I have been a Fruit Juice user for years, but I don’t think the developers were able to sync up its recommendations with Apple’s new battery management program. On my 2021 MacBook Pro, it always asked for a run of 1hr 50 minutes, no matter how much it had been used while not plugged in the previous day.
I’ve put Coconut Battery in my menu bar to be able to quickly check baterry stats.
Thanks Alan - I did not know that.
So with this optimization, can you leave your Mac, iPhone or iPad plugged in for extended periods of time?
Yes, that’s exactly the idea.
I have optimized battery charging turned on in my iPhone 13 Pro but I don’t feel like it’s working right. I’m ashamed to be so predictable, but I almost always go to bed at about 10 and at that time put my phone on a (non-Apple) wireless charger. I rarely ever use the phone at night, and take it off the charger at about 6am fully charged. But when I look at the Battery section in Settings, it shows that it charged rapidly to 100% by midnight or so, and then stayed at 100% all night. Is this going to give me reduced battery life as my 6 month old phone ages?
That looks like a classic battery optimization - the phone is initially charged and then held at a specific level for a while before it goes to 100%. I’m not sure why it starts charging so early in your case.
I just looked at mine for last night and it didn’t do optimized charging at all, but it usually does. My phone usually starts charging from 80% at about 4am; I’m usually getting out of bed somewhere between 6 am and 7 am.
When the iPhone is in optimized charging it will tell you (in my case on the lock screen) that it is holding off fully charging and by which time it expects to be fully charged. That of course is based on its assumption of when you will start using it again. In the case of @steve25 it looks like the iPhone for some reason assumes it needs to be ready by ~ 3 am. Would be interesting to see if that is indeed what it says.
Hmmm, I don’t believe I’ve ever noticed anything on the lock screen about optimized charging, or anything else especially about the charging. But again, my usual is just to place the phone on the charger as I’m going to bed for the night, so maybe there’s a message and I just never see it. When would such a message show up? When it first starts being charged, or after 10 minutes or something like that?
I’ve only seen a notification about optimized charging the first time the feature was used, which was about two weeks after I turned it on for my iPhone X and two weeks after I set up the 13 Pro. But, then again, I never look at my phone while I am in bed, so it’s possible there is a transient notification that disappears after the phone is fully charged and I unlock it the first time in the morning.
In my case the phone is plugged in and charging next to my bed. It usually aims to be fully charged by 4:30am because it has learned I get up around 6am. If I wake up around 2am, it will show 80% charged and display the message about optimized charging on its lock screen. It’s very similar in essence to what your Mac shows you under the battery menu when it’s hovering at ~80% due to OC.
