Apple PC Compatibility Cards for Power Macs
Apple PC Compatibility Cards for Power Macs — Apple has officially announced its next generation of PC Compatibility cards, designed to provide Windows and MS-DOS capability to PCI Power Macs. Two versions will be available: the 12-inch card sports a 100 MHz Pentium, and the 7-inch version uses an "entry level" 100 MHz 586 chip (a third-party x86-compatible chip) that’s roughly equivalent to a 75 MHz Pentium in performance. Both cards incorporate an ATI Mach64 video controller, game port, 16-bit Sound Blaster Pro support, and 8 MB RAM (upgradable to 72 MB). Prices for the stand-alone cards will range from $800 to $1,050; Apple is also introducing a Power Mac 7200/120 PC Compatible with either a 586 or Pentium card for $2,600 to $2,800 (a substantially better value). Both the cards and the 7200-based systems should be available in June. [GD]
<http://product.info.apple.com/pr/press.releases /1996/q3/960422.pr.rel.pccompat.html>
