Dantz Provides Optical Drive Firmware Updates
Dantz Provides Optical Drive Firmware Updates — If you own an older Titanium PowerBook G4 with a Combo or SuperDrive, and if you also use Retrospect to back up data to CDs or DVDs, you may need to upgrade the optical drive using a firmware update recently released by Dantz. The firmware updaters work on Matshita optical drives installed prior to January of 2003. To determine the revision number of your drive’s firmware, launch Apple System Profiler, switch to the Devices and Volumes tab, and look under the Bus heading. Be sure to read the directions at Dantz’s Web page for full details. [JLC]
<http://www.dantz.com/index.php3?SCREEN=kbase& amp;ACTION=KBASE&id=28020>
