6 comments
AirPods Versus PowerBeats Pro: Same Parent, Different Paths
AirPods are all the rage, but they aren’t Apple’s only wireless earbuds. The PowerBeats Pro buds, a product of the Apple-owned Beats by Dre brand, have key features in common with their little white cousins, yet are different enough to tempt those who might find AirPods wanting.
I’ve been using loaner units of the AirPods and PowerBeats Pro heavily for a while. Both are high-quality products, and you could even see them as complementary since they’re made with different usage scenarios in mind. But at $159 and up for AirPods, and $249.95 for the PowerBeats Pro, most people will restrict themselves to one or the other.
So it’s important to understand the attributes of each and how they fit into different lifestyles and use cases. There is quite a bit to digest, so let’s dig in.
First, the Similarities
Both the AirPods (now in their second generation) and the PowerBeats Pro are Apple to the core. Key features found in both include:
  • Syncing across Macs and iOS devices—meaning that pairing with one Apple device makes the earbuds available to all Apple devices sharing an iCloud account
  • Audio auto-pausing upon removal from your ears—assuming you have a feature called Automatic Ear Detection turned on
  • Apple’s proprietary H1 chip with a variety of enhancements over the earlier W1 chip, including Siri support, a new version of Bluetooth with a more reliable connection, faster device switching, and reduced audio latency for better gaming
  • A speech-detecting accelerometer that recognizes when you’re speaking and works with a pair of beam-forming microphones to filter out external noise and focus on the sound of your voice
Now, the Differences
These commonalities aside, the AirPods and PowerBeats Pro are strikingly different products. I compared them in a variety of ways, including fit, sound isolation, sound quality, controls, battery life, portability, water resistance, and colors.
How They Fit
Physical design, and how they fit in your ears, is the most obvious difference.
A woman wearing AirPods and a woman wearing PowerBeats Pro
AirPods are wireless versions of Apple’s EarPods with the same sculpted, hard-plastic design that tucks into your ear canal and remains suspended there, courtesy of its curved contours. This approach is sometimes controversial, since all ear canals are different, and some users don’t feel the AirPods can be seated snugly and securely enough. For some people, they’ve even been known to fall out during normal activity.
The PowerBeats Pro take a very different approach. They are vaguely lozenge-like devices, with two key attachments:
  • An angled earpiece with a rubber add-on tip for a snug fit in your ear canal regardless of size. Beats includes four sizes of tips for a customized fit
  • A soft, flexible ear hook with a curved shape designed to loop above and behind your ear in a manner that will help to hold the earbuds securely in position
PowerBeats Pro
Together, these design elements fuse the earbuds to the sides of your head to a degree AirPods cannot. But do you want that?
Those intending to use earbuds during vigorous sports would typically prefer the PowerBeats Pro, budget permitting. But others, particularly those who wear glasses or sunglasses, might find the clingy PowerBeats Pro irksome and uncomfortable. I’m no fan of the ear hook, which jockeys for position with the earpieces of my glasses. Generally speaking, I find the PowerBeats Pro less comfortable than advertised.
The AirPods have the virtue of simplicity—donning them is much less of a production than the more complex PowerBeats Pro—and, for the typical user, more comfortable.
Sound Isolation
Where do you typically plan to use your earbuds? Noisy environments, such as on a bus or train for your commute, or perhaps on planes? Or in quieter surroundings, like your home, office, or health club, or in your peaceful neighborhood on jogs or dog walks? The answer to this question has a direct bearing on which of the earbuds you should choose.
AirPods don’t form a tight seal within your ear canal—meaning all that excessive plane, train or automobile noise will just about drown out your music or podcast even if you crank the volume all the way up (which is terrible for your long-term hearing health). I’ve just about given up the use of AirPods in such settings, reserving them for quieter home and office use.Comply foam tips
The PowerBeats Pro, courtesy of their rubber ear tips, seal out external sound to a far greater extent, making them more suitable for noisy environments. You can enhance the noise-blocking even further with third-party ear tips. I have long been a fan of Comply foam tips, which have superb sound-isolation qualities, and are available for the PowerBeats Pro.
To be clear, the PowerBeats Pro audio-isolation qualities aren’t the active, adjustable, battery-powered kind of audio cancellation available with fancy headphones from Bose and the like. We’re just talking about passive, partial sound isolation.
Of course, sometimes it’s better to let additional ambient noise in, so you can hear that car coming up behind you. Don’t compromise safety for sound isolation.
Sound Quality
Which sound better? You’ll get what you pay for. The higher price of the PowerBeats Pro buys you better audio quality—and, to my relief, not the bass-heavy kind that has given other Beats headphones some notoriety.
It’s a close call, though. Audio from the AirPods is just fine, at least for casual, non-audiophile users like me.
But sound isolation figures into the quality equation too. It doesn’t matter how nice AirPods sound if their audio will get drowned out. Even in the quietest of environments, the lack of ear-canal sealing spoils the experience to a degree—I continually fiddle with the positioning of my AirPods to hear them better, as I’ve long done with the wired EarPods.
Controls
You can control both earbuds to an extent with Siri via the usual “Hey, Siri” summons. Beyond that, they diverge. AirPods, true to Apple’s minimalist tendencies, have no physical controls, but the PowerBeats Pro do.
That said, AirPods have a double-tap feature. You can select the left or right AirPod and then decide what you want that double-tap to do: summon Siri; play, pause or stop audio; skip to the next audio track, or go back to the previous track.PowerBeats Pro logo button
Some users prefer actual, moving buttons, and the PowerBeats Pro provides them. You use the large, rounded button with the Beats logo on the side of each bud to pause or play audio (one press), skip to the next audio track (two presses) or go back to the previous track (three presses).
PowerBeats Pro volume button
This logo button also works for phone calls: press once to answer or end a call, to answer a second incoming call and put the first on hold, or to switch between two active calls. Long-press the button to decline a call.
Want Siri? Press and hold the logo button.
A small rocker button atop each earbud lets you increase or decrease the volume. Using the volume button on either bud automatically adjusts the setting on both.
Battery Life
Apple rates the AirPods at up to 5 hours per charge for over 24 hours if repeatedly recharged in their battery case until it runs dry. By comparison, Beats says that the PowerBeats Pro will last up to 9 hours per charge, and more than 24 hours when recharged in their case.
Realistically, how long the earbuds go on a single charge means little to me since I’d never use them nonstop—that is, without putting them into their case on occasion—even for 5 hours.
Battery-case capacity matters more to me since it determines how long I can use the earbuds without needing to replenish the set at a power outlet—when off the grid camping, say—and, in this regard, the AirPods and the PowerBeats Pro are no different. A 24-hour case capacity translates into multiple days of real-life use, which is great.
Also useful is their fast charging. The AirPods will give you 3 hours of use with a 15-minute charge, while the PowerBeats Pro get 90 minutes on a 5-minute charge and 4.5 hours on a 15-minute charge.
Portability
AirPods are famously compact—in their battery case and out. This is not always a good thing; the tiny buds are notoriously easy to lose (as New York City’s Metropolitan Transit Authority recently documented), and they can get inadvertently run through the wash (as I’ve done on multiple occasions).
In contrast, the PowerBeats Pro are a bit bigger and more awkwardly shaped, meaning you’re less likely to drop or misplace them. But their battery case is a monster compared to the case that the AirPods use, making the PowerBeats Pro much less convenient to take with you.
PowerBeats Pro case
Water Resistance
Apple makes no official claims about the water resistance of the AirPods. I can anecdotally tell you my first-generation AirPods survived several runs through the washer and dryer, but that should in no way guide your buying decision.
The PowerBeats Pro have an IPX4 water-resistance rating, meaning they can withstand splashing liquid (such as rain or quick faucet rinse-offs) but can’t be submerged for any significant length of time. This makes PowerBeats more appropriate for sweaty workouts, although AirPods are commonly used in this manner with no significant complaints.
Charging Options
The second-generation AirPods ushered in Qi wireless charging with an optional wireless-capable case (see “Second-Generation AirPods Gain “Hey Siri” and Optional Wireless Charging,” 20 March 2019). That means you can charge AirPods alongside an iPhone and Apple Watch on any number of combo wireless chargers (see “RIP AirPower, but Great Gadget Chargers Abound,” 29 July 2019).
However, the special Qi-compatible battery case raises the cost of a case-plus-buds combo from $159 to $199. You can also buy the wireless case by itself for $79 for use with first-generation AirPods.
Alas, the PowerBeats Pro lack a wireless-charging option. Their battery case is Lightning-only.
Colors
To paraphrase Henry Ford, you can get AirPods in any color you want, as long as it’s white. Likewise, until recently, PowerBeats came only in black. Those craving other colors did have options that didn’t come cheap, like ColorWare paint jobs for AirPods and PowerBeats. But last month, Beats added three new color options: Ivory, Moss, and Navy. They’re distinctly muted shades, but they give you an opportunity to move beyond the monochrome.
PowerBeats Pro colors
Making Your Selection
As I’ve noted, the AirPods and PowerBeats together covered all of my listening needs nicely, and it wouldn’t be insane to buy both—if you can afford that. Most can’t and have to choose. Here’s the bottom line:
At $160–$200, AirPods are more affordable, even with a wireless-capable battery case, are less complicated to use, have greater portability with a case that slips easily into a pocket, sound decent, and are comfortable for most users. They’re the best overall option, assuming you’re sticking with Apple (and probably even if you look to other vendors, to judge from their popularity).
With a $250 price tag, the PowerBeats Pro are more specialized accessories for those with more particular requirements. They sound better overall—and even more so with sound isolation courtesy of those soft-rubber tips. They’re also better for extreme athletics since they attach more securely and are more sweat-resistant. And although it’s hard to imagine paying a $50 to $90 premium just for some optional colors, you can do that if you want.
Comments About AirPods Versus PowerBeats Pro: Same Parent, Different Paths
  1. While AirPods have no noise cancelling capabilities, I find they easily fit inside the ear protectors I occasionally use when operating power equipment in the garden. When doing so, as a safety precaution and since I mainly listen to podcasts, I usually only wear one AirPod at a time.
  2. I believe they are made by 3M from an Ace Hardware store. A feature I like is that the earpieces are not in a fixed position on the headband. They can rotate 360°. That allows for the headband to, for example, sit back toward my neck if I am wearing a cap while the earpieces remain in a comfortable position on the ear.
  3. There was a neat example, under “Portability,” of how “attraction” in subject matter can lead us into typos: after referring to their case as a “monster,” the next instance of PowerBeats was spelled “PowerBeast”! :joy:
  4. Hah! Good eye, and as much as I like the idea of a PowerBeast Pro, I’ve fixed it. That sort of thing really does happen in editing a lot. The main place I hit it is when I think I’ve come up with the perfect word for some sentence and then I realize the very same word is a line or two below. My brain must have picked it up without my realizing.
  5. Suffice to say that I purchased three other pairs of TW earbuds trying to find something cheaper than Apple’s offerings. I finally ended up with the PowerBeats Pro and 100% feel they are worth the money. Airpods do NOT fit my ears even a little, so they were never really an option.
    Upsides of PowerBeat Pro:
    • Just writing “9 hours per charge” does not fully express how freeing it is to have a wireless headphone that just lasts all day. I literally just do not have to worry about it, at all. This was a regular source of anxiety with other TWEB claiming 4 and 5 hour battery life. I basically had to keep wired headphones around as a backup with the others, but didn’t feel it necessary even on a 12-hour road trip.
    • The included tips are somehow significantly better than most pack-in tips. I NEVER use silcone tips, but I actually prefer these to the Complys I bought just assuming I’d need them. It’s not as good a seal as Complys for sure, but audio quality doesn’t seem to suffer for it. I just use the Complys to mow the yard now.
    • You can actually make phone calls with them. For some reason, almost all other TW earbuds completely fail at this pretty basic task. Jabra told me they believe it’s a fundmental limitation of any bud-style design. I don’t talk on the phone a lot, but it was so infuriating to start every phone call with “What? Can you hear me? Hold on…”
    • In general they just fatigue my ears far less. The buttons are really easy to press, meaning you never jam them into your ear pushing them. Since they don’t wedge into the ear canal to get a good seal, they don’t hurt after wearing them for hours. And I can’t even imagine how they’d fall out.
    Downsides of the PowerBeat Pro:
    • As mentioned, these are a non-starter if you wear glasses. I put up with it when I wear sunglasses, but I can’t imagine having to deal with that all day.
    • Connection is very good, but not perfect. For all it’s other flaws, the Jabra Sport Elites where absolutely flawless in their connection (though both are in a different class than anything else I tried). These run into very occasional hiccups, which are always solved by disconnecting and reconnecting.
    • The case is hilariously large. This isn’t a huge problem with the aforementioned battery life, but it does mean that I leave the case at home most days and the earbud just hangs around loose in my pocket more than I’d like.
    • I thought for sure that they’d show up in Apple’s “Find My” app, but they don’t. All the other TW earbuds I tried had an app that would show you their last known location and make a whistling sound to help you find one if you lost it in the couch. The PBP have nothing to help you with that, and is a surprising omission frankly. Maybe when the start doing UWB things.
Avatar for ace Avatar for julio Avatar for saundebn Avatar for sinarades Avatar for Grabauski
